Subject Topic: Nissan 3 cylinder Post ReplyPost New Topic
jdavis
U.S. - Virginia
Posted: Mar 09 2010 at 4:11pm | IP Logged Quote jdavis
My 01 frontier xe runs on only 3 cylinders when it gets warmed up. New
plugs, wires, rotor, D cap, nothing seems to help. Any ideas? My mechanic
wants to put on a new distributor. Is she a goner?
Back to Top View jdavis's Profile Search for other posts by jdavis
Posted: Mar 09 2010 at 6:23pm | IP Logged Quote frontierguy
Is there any spark coming out of the dist for the cyl that isn't firing??? Is it an aftermarket cap and rotor????
08 Frontier SE KC 4X4 6speed
08 KTM 200 XC-W sold
09 KTM 200 XC-W
07 KTM 250 XCF-W sold
06 Altima SL!!
jdavis
U.S. - Virginia
Posted: Mar 15 2010 at 6:35pm | IP Logged Quote jdavis
Just got it back from the mechanic. He says the problem is electrical and
has replaced plugs, wires, cap, rotor, and distributer( after market). We did
discover that as long as you turn off the overdrive it runs fine (the service
engine light blinks but no more shuttering). Not sure where to go next.
Can't afford to dump much more $ into it.
Posted: Mar 15 2010 at 7:15pm | IP Logged Quote frontierguy
If the ses lite is flashing, that means there is a misfire, I would find the cause of the misfire before you destroy a cat if you haven't already. PS find a technician that knows what he is doing rather than throwing parts at it!
09 KTM 200 XC-W
06 Altima SL!!
