Subject Topic: Squeaking from rear in reverse Post ReplyPost New Topic
Posted: Apr 05 2010 at 7:38pm | IP Logged Quote frontierguy
Jimmy54 wrote:
Instead of spraying the u joint you should replace it, if you take it apart you
will most likely see the needle bearings are all rust.
I second that!!!! Spraying with WD is only helping you to isolate the noise, not fix it.
davidjbrady
Posted: Apr 06 2010 at 8:15am | IP Logged Quote davidjbrady
Correct me if I am wrong, but don't the Frontiers use CV joints in the drive shaft as opposed to U joints? Which joint did you end up putting lube on?
08 Frontier CC, 4X4, LWB
Posted: Apr 06 2010 at 8:13pm | IP Logged Quote frontierguy
Front drive shaft has u-joints, rear has one on the front of the driveshaft(CC, KC has 2 on the rear shaft.
wahoo8837
U.S. - Virginia
Posted: Apr 10 2010 at 9:04pm | IP Logged Quote wahoo8837
final update:
the squeaking came back one day after i used the wd40. i went to pep boys
and got some greese and greesed the joints of the drive shaft. The
squeaking went away but came back 3 days later. I took it to my local shop
and got it back today. One of the front u-joints would only pivot in one
direction. They replaced the u-joint for $100, problem finally solved.
Thanks for the help!
Andrew
Back to Top View wahoo8837's Profile Search for other posts by wahoo8837
<< Prev Page of 2
