| Posted: Jul 23 2007 at 12:55pm | IP Logged
Hi
I am new to the forums and recently purchased a 2005 Frontier Se 4x4 Extra cab. I've purchased the headunit off of e-bay. It's a single din unit and has navigation on it. However, the nav requires the vehicle speed sensor wire to be hooked to it and I've not been able to locate that wire and also a reverse light wire hooked up according to some posts on crutchfield. Also are single din dash kits availabe for the Frontiers? I ask because crutchfield didn't list them as an option... I usually just go to Wally-world and pick one up for an install.
Thanks for any help,
Eric
edit: I recently found this article regarding a similar install on an 01 Pathfinder
http://x.nissanhelp.com/forums/pathfinder/3438-where-speed-s ensor.html Is the wiring similar to that of the 05 Frontiers?
