| Posted: Feb 10 2008 at 11:43pm | IP Logged
stang702;
I carry a screw scissor jack because it’s low and a hydraulic bottle jack plus a bunch of wooden blocks. You can lift the body then lift the axle. The high lift jacks are nice and can be used as a come-along but you need to to rig up things to hook them to on these modern trucks.
Why is it that the politicians in D.C. are the only ones that don’t know there are better things to make Ethanol out of than corn?…  Answer… They know! They know! Guess why they don’t correct the problem.
