Mobile Audio / Electronics
Subject Topic: Does the 2004 Frontier have an amplifier? Post ReplyPost New Topic
karlovac
Posted: Feb 12 2008 at 12:51pm | IP Logged Quote karlovac
I just installed a new aftermarket stereo in my 2004 Frontier Crew cab. Previously, it had the standard 6-speaker stereo. I did not have the Rockford Fosgate head unit.
I didn't connect the blue wire in my new stereo. I think it's supposed to go to the amp.
My question is: should I have conneted that blue wire? Does my truck have an amp?
I did not think so, but I noticed something electrical under the front console as I was running the wiring. I couldn't figure out what that might be, except maybe an amp. By that point I'd already soldered all the connections, so I didn't bother with the blue wire.
Thanks,
Antun
Back to Top View karlovac's Profile Search for other posts by karlovac Visit karlovac's Homepage
jers
Canada
Posted: Mar 06 2008 at 9:37am | IP Logged Quote jers
If you don't have the Rockford Fosgate head unit, I don't think you have the amp. It wasn't the Bose head unit either was it? Can you snap a pic of the mystery electronic component you are wondering about?
Back to Top View jers's Profile Search for other posts by jers
dsarains
U.S. - Nevada
Posted: Feb 07 2010 at 3:48am | IP Logged Quote dsarains
Its most likely the ECM (engine control module). Its a silver box mounted below the center console, towards the very front of the passenger compartment. The other silver box directly under the armrest of the center console is the SRS diagnosis system.
Check this pic, if it helps:
Electrical Unit Locations
Better late than never I suppose, just noticed the post date. Go me.
2004 Frontier XE King Cab
V6 3.3L (VG33E) - 5 Speed
Push Button Ig. + Kill Switch
Kenwood 6.5" Front
Alcoa Forged 16" Rims
BFG Rugged Terrain T/As @ LT265/70
Back to Top View dsarains's Profile Search for other posts by dsarains
karlovac
Posted: Feb 07 2010 at 11:16am | IP Logged Quote karlovac
Thanks for posting that. The box I was referring to was the Airbag diagnosis one, according to that diagram.
What book is that out of by the way? Is it the Haynes one?
-Antun
dsarains
U.S. - Nevada
Posted: Feb 07 2010 at 4:42pm | IP Logged Quote dsarains
Its actually a pic I saved. The building we own for out shop is split in half, and the other half is an auto repair place. They let me go over there and use their online thingy - pretty much every car in existence. I just save the stuff that is useful - Ive got almost all the wiring and mechanical diagrams for the major systems for the 2004 Frontier XE with VG33E.
If you need a specific thing, let me know. The pics I have are what I used to figure out my ignition system wiring, and bypass it all to do my push-button (or momentary spring-toggle in my case) ignition.
Kenwood 6.5" Front
