           | Posted: Oct 23 2005 at 3:21pm | IP Logged |   |
 |  Beware 05 Frontier owners who off-road their 4WD... One of the guys I know in our off-road club has substained major damage to the front aluminum differential housing and internal gearing. It seems that he had impacted the bottom part of the front 4WD differential on some hard ground and/or rocks inwhich resulted in seriously cracking open the differential case, leaving a large hole in the back of it. Unlike the 01-04 Frontier 4WD models which have steel front differential housings, the new 05 design has an aluminum front differential case/housing. This type of damage (especially if gone undetected) will cause leakage of the differential fluid and binding of the differential gears beyone the point of repair. It makes no difference if the vehicle is in 2WD or 4WD as turning of the axle and open differential without lubrication will distroy it quickly. Needless to say but this type of incident/damage would also cause the owner major expense to have it replaced as well.
 Best advice at this point if you plan on 4wheeling your 05 Frontier, is to invest in undercarrage armor to help protect the exposed front aluminum differential case/housing before you end up like this...
 Here Comes TNT Trouble
