pops Newbie
Posted: Dec 15 2008 at 3:35pm | IP Logged
1998 Nissan Frontier, 4 cyl. 5sp. 4X4
Check engine light is on and I had a Haynes book for this truck but do not know what happened to it. The check engine light came on a few days ago, the truck is still running just fine. I need info on how to get the code so I can find out what is going on. Also, where can I find a list of codes for this truck?
Thanks Very Much
__________________ DDH
Boomer Senior Member
Posted: Dec 15 2008 at 3:56pm | IP Logged
Here is a site that gives the codes.
Nissan On-Board Diagnostics (OBDII) Codes - Nissanhelp.com
pops Newbie
Posted: Dec 15 2008 at 7:22pm | IP Logged
Thanks for the info. Another question: How can I get the code without some fancy equipment? On some vehicles there are two pins that can be jumped and then you read the flashes of the check engine light. Can this be done on my Nissan? If so, which pins do i need to jump to get the code?
Thanks Again
Posted: Dec 15 2008 at 7:38pm | IP Logged
Do you have an Auto-Zone or Advance Auto near you? They will scan for no charge. Just don't let them sell you their aftermarket stuff they think will fix it!!
pops Newbie
Posted: Dec 15 2008 at 7:40pm | IP Logged
Yes, there is an Advance Auto in town where I live. I will ask them to check it for me. Thanks Again
pops Newbie
Posted: Dec 20 2008 at 9:32am | IP Logged
P0440- What to check for? I don't have that info.
Posted: Dec 20 2008 at 7:22pm | IP Logged
Try tightening your gas cap. You apparently have a leak in the EVAP control system. If that does not do it, try replacing the cap. Past that, look for cracked hoses in the EVAP system.
P0440 is for evap small leak.
Posted: Dec 20 2008 at 7:28pm | IP Logged
Sorry tried to copy and paste some info, didn't work. As Boomer says, check your gas cap(make sure it is a genuine Nissan cap) and the filler tube where the gas cap seals(no rust). Possible dirty or sticky VCV, cracks near the attaching nuts in the canister for the VCV, leaking VC/V bypass valve(due to rust), lots of possibilities.
pops Newbie
Posted: Dec 20 2008 at 7:41pm | IP Logged
Thanks. It has been awhile since I did much work on anything automotive. I will check these things out. Again, thanks for the info. Sure wish i couldfine my book. I may have to get another one.
