Posted: Dec 18 2008 at 7:28pm | IP Logged
No. The rad comes out the top. Remove lower eng cover, drain coolant, disconnect trans cooler hoses(if auto), disconnect coolant hoses, remove lower section of shroud, remove attaching brackets, lift out. It's a lot easier to do than to explain, basically one bolt at a time.
