| Posted: Jan 03 2009 at 8:36am | IP Logged
Yes, it is the flip up sunroof...I'm pretty sure it isn't the roof rack.
I also removed the front plastic wind deflector (I'm guessing that is what it is called) that is attached to the roof rack. For all that have these type of sunroofs...remove the glass totally out of the frame (very easy to do, follow owners manual) and look inside the tray (gutter area) on top of your roof and you should see two "flaps" on hinges that move...DOES ANYONE KNOW WHAT THESE THINGS ARE USED FOR??? I believe these are moving up and down when driving which is causing the annoying noise.
Thanks again...
