| Posted: Jan 29 2009 at 4:55pm | IP Logged
I'm just about in the same boat.
1. Change the fluids in the front and rear diffs. 75W-90 Syn in the rear and 80W-90 dino in the front.
2. Change transfer case fluid with Nissan D ATF.
3. Have the trans serviced and fluid drained and replaced per your dealers recommendations.
4. Coolant flush and fill with Nissan coolant.
The first two you can do yourself but always remeber to take out the fill plugs before the drain plugs! Have the deaqler do the other two. Put a drop of oil on the door hinge pins and the hood hinges. I think you should be good to go for another 30-40,000 miles.
