| Posted: May 05 2009 at 9:29am | IP Logged
Okay, I found the answer to my own problem. On the AutoZone website I found a chart listing resistances for certain temperatures, unfortunately I am having an error uploading the image.
At 32 degrees (F) the resistance should be .62 - 1.05 M ohm
at 122 degrees the resistance should be .065 - .094 M ohm
at 212 degrees the resistance should be .011 - .015 M ohm
On a different forum, someone with an S14 used a 100 K ohm resistor and blocked off the EGR, which tricks the computer into thinking the intake temperature is just under the 122 degree mark, so I think I will try this.
If anyone is interested in doing to same (it should increase fuel mileage and power a little), I will post pictures and results when I am finished.
