Mobile Audio / Electronics
Subject Topic: 08 Frontier wiring. Post ReplyPost New Topic
skitz0721
U.S. - Nevada
Posted: May 24 2009 at 6:10pm | IP Logged Quote skitz0721
I have the 08 Crew Cab with standard radio. I'm trying to install a Kenwood. I just need to know what wire go to what. The only info I can find has to do with 05s.
Back to Top View skitz0721's Profile Search for other posts by skitz0721
Posted: May 24 2009 at 7:52pm | IP Logged Quote frontierguy
Wiring Diagram - Base Audio System - Part 3
Posted: May 24 2009 at 9:32pm | IP Logged Quote lakota
frontierguy;
The wiring diagram didn't work for me.
Help save the 2nd Amendment & Freedom. > Join Free:
http://www.nrahq.org/nrabonus/accept-membership.asp
bbhzx12
Posted: Jun 20 2009 at 10:32pm | IP Logged Quote bbhzx12
Drop the $12 on a metra harness and match the colors, ground to the chassis.
Back to Top View bbhzx12's Profile Search for other posts by bbhzx12
skitz0721
U.S. - Nevada
Posted: Jun 21 2009 at 8:01pm | IP Logged Quote skitz0721
cant. i have the metra harness. the problem is the truck.
bbhzx12
Posted: Jun 21 2009 at 8:25pm | IP Logged Quote bbhzx12
What exactly is the problem?  I can probably help, I have an 08 CC with a Pioneer.  The Metra harness should plug in and give you everything except ground for a standard radio.  The Merta harness and Kenwood harness should be color for color.
skitz0721
U.S. - Nevada
Posted: Jun 22 2009 at 3:45pm | IP Logged Quote skitz0721
i wired the kewood and metra harness together and and connected to a stable ground and it wouldn't even turn on. half of the wires didn't even match up.
bbhzx12
Posted: Jun 22 2009 at 7:29pm | IP Logged Quote bbhzx12
My truck is at the dealer for a wheel bearing, when I get it back I'll pull the radio and get you the info you need, and some pics to help.
skitz0721
U.S. - Nevada
Posted: Jun 23 2009 at 4:36pm | IP Logged Quote skitz0721
thanks a lot. this has been driving me nuts about a month. i will pull mine and take some good pics to show what i'm talking about to. i will try to take care of that as soon as i get a chance. on a side note. it is scary easy to get the console apart and take out the stereo.
tim green
U.S. - Michigan
Posted: Jul 22 2009 at 9:30pm | IP Logged Quote tim green
i just repalaced my stock radio and speakers for a kenwood ddx 514 and i mounted the amp under my passanger seat any one want my stock stuff
Back to Top View tim green's Profile Search for other posts by tim green
Page of 2 Next >>
