Subject Topic: help with code P0340 on 2000 frontier v6 Post ReplyPost New Topic
happyg
U.S. - Hawaii
Posted: Jul 22 2009 at 3:26pm | IP Logged Quote happyg
2000 frontier crewcab v6
shows "cam sensor" which equates to the distributor,
versus a "crank sensor".
anyone come across this? are distributor modules available separately?
tia
Back to Top View happyg's Profile Search for other posts by happyg
Posted: Jul 22 2009 at 8:19pm | IP Logged Quote frontierguy
Usually what goes bad is the bearing- it comes apart and pieces float around inside. I have replaced them before with success. You will have to disassemble , get the # from the old bearing and match it up. Nothing is serviceable inside the distributor through Nissan.
happyg
U.S. - Hawaii
Posted: Jul 22 2009 at 8:28pm | IP Logged Quote happyg
module/led/reader was bad.
since they dont sell them (only as a distributor assembly)
found a newer 3.3 at the salvage yard and took it from there.
fine now.
dang i hate electronics, lol
