| Posted: Jul 26 2009 at 11:54am | IP Logged
if you have a multimeter and a general mechanical knowledge it can be done. Basically it's just a matter of using the multimeter to check for resistance through the motor using the connector pins.
If you're scratching your head at that statement above, I would have a dealership or a decent shop check it out.
But I can tell you from what you already wrote, that I'm 99% sure it's the motor... 1% being that the connector for the motor is unplugged.
