| Posted: Sep 03 2009 at 11:11am | IP Logged
Well, you could take the extender tabs out of the Utilitrak,put the extender in them, load the cycle and then reinsert the extender tabs with the bed extender in them back into the Utilitrak. That should work and solve your problem.
But why not leave the extender off. Use the large Utilitrak clips and tie your bike to them with ratchet straps Put two in the front of the bed and one on each side. Bike should be very stable like this if you pull the straps tight.
