Posted: Sep 22 2009 at 8:45am | IP Logged
I just purchased a 2009 Frontier CC 4x4 and wanted to level it and even add a little lift. I've seen alot of people use the PRG2.5" spacer for the front and 1.5" blocks for the rear. I will be towing a boat so extended shackles will not work.
Could I us the Bilstein adjustable shocks to lift the front 2" and then Bilstein adjustable shocks to lift the rear 1"? Would the ride still be good?
What other modifications would I have to make if I raised it 3" in the front and 2" in the rear? Any help would be appreciated.
