Eric Newbie
| Posted: Jan 03 2010 at 12:56pm | IP Logged
Just purchased a 2004 Frontier, and noticed a noise coming from the supercharger. 147k miles not sure if this is normal. When the car is first started there is no noise, after warm up the supercharger seems to engage and there is noticible vibration/noise from the supercharger. Has there been any problems with the superchargers and does anyone know how long they last before problems?
__________________ Eric
| Posted: Jan 04 2010 at 8:05pm | IP Logged
Be sure to use Premium Hi-test fuel.< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
ergomoto Newbie
Online Status: Offline Posts: 26
| Posted: Mar 06 2010 at 1:23pm | IP Logged
Eric, have you gotten to the bottom of the cause of this noise? I've been wrestling with the source of a light grinding noise seeming to emanate from the S/C after warm up as well.
Mark S
__________________ 1965 Datsun 1300 520 Pickup
2003 Nissan Frontier S/C SE Crew Cab Std Bed
Is that what you wanted it to look like?
Eric Newbie
| Posted: Mar 06 2010 at 6:03pm | IP Logged
Yes, I had to replace the S/C. I bought a rebuilt S/C for about $700 online. Noise is no gone.
Eric Newbie
| Posted: Mar 06 2010 at 6:04pm | IP Logged
Noise is gone.
ergomoto Newbie
| Posted: Mar 06 2010 at 6:22pm | IP Logged
Interesting. Thanks for the reply post Eric. Too many S/C Frontiersmen are down the road now, along with their experiance.
I've been eliminating other plausible sources for my hissing gind, but am quickly coming to the conclusion that the only feasible fix for this is a S/C rebuild, as it's likely the bearings, as you found. I have purchased the bearings and seal associated with a rebuild for this unit will be simply pulling the S/C and dropping it at my local machine shop for finesses cleaning, and pressing off and on of them.
Glad to hear you got yours sorted. Our experience with these Eaton M62's chewin' through their bearings should advocate for regular elective S/C oil changes -all the more for a new unit one might want to keep in better shape for longer!
Cheers, Mark S
