Subject Topic: headliner falling down Post ReplyPost New Topic
dolfans
U.S. - North Carolina
Posted: Feb 26 2010 at 1:45pm | IP Logged Quote dolfans
Truck is a 98 extended cab and the headliner is falling down. What can i do to fix this myself? If i got a can of adhisive glue and sprayed it would that work? Can i take the headkiber board out of the truck? Any help will be useful thanks
Back to Top View dolfans's Profile Search for other posts by dolfans
Posted: Mar 01 2010 at 10:40pm | IP Logged Quote lakota
I'm hoping someone will post up a good fix for this... got the same problem.
Don S..
davidjbrady
Posted: Mar 02 2010 at 8:17am | IP Logged Quote davidjbrady
Not sure, maybe rubber cement? I used that on my old Mustang, and it worked well. Is it "starting to come down" or is it "way down"?
08 Frontier CC, 4X4, LWB
dolfans
Posted: Mar 02 2010 at 1:20pm | IP Logged Quote dolfans
It is all the way down. I believe my Father one time had a s10 and he used adhesive glue on that headliner. But i dont know if he sprayed it and then put the cover over the board and that was it. Or if he pushed/rolled etc it down. How hard is it to take the board out ? I can take the seats out if it helps. Thanks
dolfans
Posted: Mar 07 2010 at 12:18pm | IP Logged Quote dolfans
How do i remove the panel on the extended cab part? The part around the window. I looked and pulled the rubber/vinyl around the door. Has no screws and i barely pulled on the panel and nothing. I want to take off the head liner to sray the the maaterial on to the board. How do i remove the lights at the front and back. Thanks
dolfans
Posted: Mar 07 2010 at 4:33pm | IP Logged Quote dolfans
I took it out today. I took the 3 plugs things out,the handle on the pass side above the door,the visors,the door molding,and the panels on the extended cab and the winshield, and the lights. It was hard getting it out with it being a extended cab and a 5 speed and the steering wheel in the way. I will hate putting it back in. Let the fun begin getting the old glue off. I found a website that helped. www.wlsheadliners.com
