eric's4x4sc Newbie
Posted: Mar 01 2010 at 8:56am | IP Logged
I have 2001 4x4 sc has anyone ever changed the spark plugs? truck has 82,000 miles and I was thinking about changing them but it looks like the supercharger has to come off to get the ones on the right side of the engine.
__________________ eric
Posted: Mar 02 2010 at 3:40pm | IP Logged
#1 plugs are good for 105K #2 the right side is the passenger side, when referring to right or left, it is from sitting in the drivers seat. #3 All Data says to remove the air inlet on the side of the plenum, my 55 yr old brain can't remember if it has to come off or not, see very few S/C Frontiers. It also says 1.4 hrs for spark plug replacement, so I doubt that the S/C has to come off. Can double check at work Wed. if I go, been sick with sinus infection.
osccean23 Newbie
Posted: Mar 07 2010 at 1:36pm | IP Logged
if you have 3.3 like my 02 sc , the one on passeger side is easy, the hard part is driver side you may need two swivels had a hard time for the center one driver side , if i were you i would blow tha area with air compreessor so dirt wont fall in spark plug hole , good luck to you
__________________ riding ridin
