jasonc Newbie
Posted: Mar 05 2010 at 2:26pm | IP Logged
2002 XE-V6 bought used in 2006.
I found a black plastic box a little bigger than a deck of cards under the dashboard just to the right of the steering column. It has a little door on it. Inside are some configurable pins or jumpers. It has a wiring connector with quite a few wires connected to it. There is also a wire that connects to a flat plug looking device that is screwed to the bottom of the dash. It has "6900A" on one side. The other side has some instructions for configuring the pins.
Is this a security device of some kind?
Posted: Mar 05 2010 at 7:24pm | IP Logged
Does it say Nissan on it anywhere or have a part # on it??? It may be a control unit for an aftermarket security system. Is it mounted with a bracket or zipped tied to something?
drewbaby625 Newbie
Posted: Mar 10 2010 at 9:35pm | IP Logged
i have never seen anything like this in my fronty i have
the same yr and model and i have had pretty much every panel in the truck taken off and have never seen anything
like this. it must be some after market device
__________________ 02 3.3 xe
halo projection headlights
upgraded front and rear bumper
2 and 3 tone air horns
15" power acoustik mofo
led neon
25,000k hid
tinted windows
off road lights
kinetik hc1400
warn wi
jasonc Newbie
Posted: Mar 16 2010 at 1:40pm | IP Logged
I've discovered that it is a security system.
http://www.magnadyne.com/index.cfm?MasterAction=Item&Inv MasID=5237&Web_CatID=300
I haven't been able to find any instructions for it yet though...
