sweetNlow Newbie
Posted: Feb 21 2006 at 2:50pm | IP Logged
i got a 99 frontier xe. i lowered mine with the torsion bars in the front then i just took out a leaf spring in the back. (free lowering is awsome)...anyway to adjust your torsion bars climb under your truck directly underneath your driver side door.(same on both sides) you will see a bracket that holds the bar in place, its pretty close to the frame, in the bracket that holds in on there with be a nut around the end of the bar, you can loosen or tighten the nut on the end of it and that will lift or lower your truck, depending on which way you want it to go.
__________________ it's got da cool air!!!
