         fknbean Newbie
           | Posted: Apr 13 2010 at 1:16pm | IP Logged
 hey guys
 checking in from Hawaii. I have a 08 se crewcab longbed auto. with
 62500 miles. a few days ago my rear end started to make noise with
 clicking and what felt like the driveshaft slipping out. that happens at
 low speeds while turning and sometimes in a str8 line. I can floor it
 and it'll catch the gear perfect. I took the truck into Goodyear and they
 said it's the rear differential and they can't help me. I called around
 and someone told me that Nissan Corp. could still fix it under the
 warrenty. I do a lot of driving on this truck daily atleast 50 a day and I
 do carry some weight from time to time. I have also have a 04 frontier
 that was used for work and that has 132000 miles with no drivetrain
 problems. so is this problem I'm having has it happened a lot to other
 trucks of 2008 or of the same design?
           | Posted: Apr 13 2010 at 8:05pm | IP Logged
Are you sure it is not a u-joint concern? Is the rear diff ever submerged in water? The vent is really crap due to rusting and plugging up causing pressure build-up and leaks. I mounted a plastic GM vent up along my frame via a hose and nipple from an older Pathfinder.
         fknbean Newbie
           | Posted: Apr 14 2010 at 12:30am | IP Logged
 Pathfinder. |
  the truck has never been that much
 underwater. i warm up everyday. the truck hasnt even really
 made 2 years old yet. granted i speed but this early in the
 game is kinda odd to me. ive made one aftermarket upgrade
 and that was with the Stillen intake nothing to the exhaust
 and nothing to the gearing.
           | Posted: Apr 14 2010 at 7:21pm | IP Logged
What do you mean by "that much under water"????? Have you checked the fluid to see if it is milky looking????
         fknbean Newbie
           | Posted: Apr 25 2010 at 1:44pm | IP Logged
I'll be checking with the Nissan dealrship here
 maybe they'll fix it
