jimmy3003 Newbie
Posted: Apr 20 2010 at 12:12pm | IP Logged
c0mpressor kicks on,clutch engages,freon charge is good.still no cold air.
__________________ jimmy2003
Jimmy54 Groupie
Posted: Apr 20 2010 at 3:26pm | IP Logged
Did you hook up manifold gauges? The pressure readings should be able to
tell you whats wrong!
jimmy3003 Newbie
Posted: Apr 20 2010 at 6:17pm | IP Logged
I dont have gauges,but had it checked at a shop that did.The guy said that all he could figure was that the guts inside the compressor may not be turning.
Posted: Apr 20 2010 at 8:03pm | IP Logged
I think I would find another shop!
Jimmy54 Groupie
Posted: Apr 21 2010 at 7:59am | IP Logged
Hard to tell without gauges, but with the compressor running, feel the line
coming out of the compressor it should be hot, and the bigger line by the
accumulator should be cold. I am not sure if it has a electronic orfice valve
(frontierguy will know) they can get stuck, if it has a "normal style orfice" it
could be clogged!
wa1t3rb74 Newbie
Posted: Jun 11 2010 at 8:42pm | IP Logged
Same problem here, 2006 Frontier Crew Cab. When I turn the AC on 1 it does not blow but AC and Recirc are activated. However, 2-4 do not turn AC on at all and in fact 2 does not engage fan at all as well as Recirc is off. I just charged the line with r134 and still nothing!
__________________ Clanger
