Subject Topic: 2001 nissan frontier cruise control Post ReplyPost New Topic
mofugger333
Posted: Jul 04 2010 at 3:08am | IP Logged Quote mofugger333
when i hit the cruise button the light comes on....when i
go to set it .....it will not engage.... can anyone help me
out and give me some suggestions to what the problem could
be,,,,,i have checked the wires going to the unit, the
cable going to the throttle body is fine, fuses are fine,
brake lights are all good
Back to Top View mofugger333's Profile Search for other posts by mofugger333
Posted: Jul 06 2010 at 8:45pm | IP Logged Quote frontierguy
Can't remember if there is a vac. hose on the 01, if there is make sure it is connected and no cracks in it. May also have a faulty brake lite switch.
Peninsula2010
Posted: Jul 07 2010 at 11:37am | IP Logged Quote Peninsula2010
Ok, will keep that in mind when I talk to the dealer as it is there at the moment as the truck is under warranty.
If they dont find it, which wont surprise me at all then I will try out those ideas.
Thanks everybody
Back to Top View Peninsula2010's Profile Search for other posts by Peninsula2010
mofugger333
Posted: Jul 07 2010 at 3:55pm | IP Logged Quote mofugger333
no there is no vacumn hoses...its all electric.....and
where would i look to see if i have a faulty brake
switch?????
mofugger333
Posted: Jul 07 2010 at 5:26pm | IP Logged Quote mofugger333
ok so i located the brake switch and realized the little
rubber piece was missing that holds the switch in for the
cruise control......so i went to the hardware store and
picked up a nut bolt and washer......33 cents.....works
great now.....5 years its been since it last worked..thanks
frontier guy
