Recommend New Section
 Nissan Frontier Forums : Recommend New Section
Subject Topic: DIY Section Post ReplyPost New Topic
Brutus3383
U.S. - Colorado
Posted: Jul 05 2010 at 12:00pm | IP Logged Quote Brutus3383
Moderators,
any chance you could get a DIY section going?  (Or did I flat miss it on here?)  Acurazine.com has a great setup that I use for my '04 Acura TL.  It's the main reason I use their site.  I've seen some great DIYs with pix here, but it seems piecemeal (like the recent excellent CAF DIY).  Would be nice if they were all in one spot by generation.  My '07 is coming up on 3 yrs old and I'm looking at DIYing the following per the Haynes manual:
  • Brake fluid flush
  • Check PCV Valve
  • Cabin Air Filters
  • Transfer case fluid
  • Front Differential oil
  • Rear Differential oil
  • ATF fluid and filter (including pan gasket and O-ring for AT strainer
  • Add external radiator cooler (someday)
  • Seaform engine
  • Coolant flush & fill
  • Engine oil & filter of course
Haynes is pretty good, but it's always nice to see other folks pix and hear their tips and tricks that Haynes/Chilton usually doesn't have.
Many thanks for a great site!
r/Pat
2007 Fronty Crew Cab LE
Only mod: Bak-Flip Tonneau Cover
Back to Top View Brutus3383's Profile Search for other posts by Brutus3383
Posted: Jul 06 2010 at 10:07am | IP Logged Quote kcidmil
You will find that on the Problems and Technical section.
Brutus3383
U.S. - Colorado
Posted: Jul 06 2010 at 10:29am | IP Logged Quote Brutus3383
Ok Ben.  We'll stick with ye 'ol "Search and hope" when it comes to preventive maintenance DIYs.
Posted: Jul 07 2010 at 9:34am | IP Logged Quote kcidmil
If we come across a good write up it gets turned into a sticky.
