| Posted: Feb 02 2006 at 7:06am | IP Logged
I have one better than BG44k... Sea Foam.  This is the only complete cleaner that can be used on the 3rd Gen Maxima (all it's components are very sensitive) and it does wonders.  There's no need to take it back to the dealer.  BUT, if you use it in your oil, you need to get an oil change within the first 500 miles (use it towards when you're due)  And you'll need to get another one right after that about a 1000 miles.
If you go to clean the TB and such, I would remove it.  It just makes it that much easier.  Also, you eliminate 2 risks.
1.) Putting too much cleaner in, and when you go to run it, it ignites and back fires out the intake 2.) you accidently get some cleaner on the MAF sensor and ruin it.  They make a special cleaner just for that.
You can use either Carb & Choke Cleaner, or Brakleen.  They're made out of the same ingredients, Brakleen just has one more added than C&C.  We honestly use Brakleen like water in our shop.  Also, if you have a old toothbrush you don't use anymore that would help as well.
Before I forget... then one drawback to Sea Foam is smoke... TONS of white smoke.
