| Posted: Jul 26 2010 at 9:17pm | IP Logged
definitely not very low tire pressure......all tires are holding steday PSI. Not sure I want to overload the front set 20 PSI beyond recommended max inflation though.
AS for the ride, it is weird.....at highway speeds it kind of feels like the back end (new tires on the rear) tracks like a dog - almost like the rear tires aren't following the same track as the front. especially noticeable when changing lanes on the freeway. It almost feels most like the sway you get from towing a trailer, except Im not towing one....weird.......I've looked under the entire rear half of the truck and nothing appears loose and the shocks arent leaking. felt the same with 45PSI as it does with 70PSI. Im going to go back to the tire shop and see what they say.
__________________ 2006 Frontier SE Crew Cab 4X4
