ksdtoday Newbie
| Posted: Aug 05 2010 at 3:23pm | IP Logged
So My ac clutch was shutting off and on, but working fine in the morning. I then noticed the condensor fan wouldnt come on, so ordered a new one, put it on and it worked for a bit, and I havent seen it come on again. The ac works ok on the highway, but warms up on stop and go. the charge is fine.
ksdtoday Newbie
| Posted: Aug 05 2010 at 8:14pm | IP Logged
Any Idea why the condensor fan wouldnt come on? Is it suposed to be on when the ac is or just when it feels like it?
| Posted: Aug 06 2010 at 8:21pm | IP Logged
Do a search for thermal control amplifier.
ksdtoday Newbie
| Posted: Aug 07 2010 at 12:10am | IP Logged
Yeah I read most that, But doesnt that just shut down the compressor? My problem is with the condesor fan. It wont come on. My compressor shuts down cause when Im at a stop no air is cooling the condensor, there for the freon heats up and the temp sensor shuts down the a/c
| Posted: Aug 11 2010 at 8:38pm | IP Logged
Sorry, guess I didn't read all of your symptoms. Looking at the wiring schematic, there are 2 fuses near the battery, 10 amp(#13) and a 40 amp(most likely a fusible link). The cooling fan relay is grounded by the ECU and or the triple switch(I'm assuming the triple switch grounds it under high pressure conditions. How about your belt driven fan clutch, is that OK?? Have you blown out the rad and cond to remove dirt and debris??
