| Posted: Mar 23 2011 at 11:13am | IP Logged
Thanks, for the reply, yes the ignition was off, key was not even in it. I did some trouble shooting yesterday, the trip odometer reset when the truck is turned off, the controls for the heat and AC/defroster, etc do not work all of the air comes out of the vent s in the dash. The AC light or air return does not seem to work. All of the other electrical options work, lights, headlight etc. I did check any fuse that seemed to part of this system and they were all good. I also unhooked the battery cable for 10+ minutes to see if that would help, not. I am thinking my next step is to have the truck put on a computer to check for any error codes. Suggestions are appreciated.
