rwpaint12 Newbie
| Posted: May 09 2011 at 9:44pm | IP Logged
Hi, my 05 Nissan Frontier SE, started giving me some
problems a few weeks ago. Wen i gave it start it would
start shaking and all of the gages would go crazy....i was
told by by one mechanic that it was the fuel pump, but i
didn't believe him so i went for a second option...the
second mechanic was a joke...told me that it was the air
intake sensor and it wasn't that...my dads good friend is a
good mechanic and came to see the truck and put the scanner
on it and nothing came out...he had me change the crank
sensor and the coolant sensor...now it starts just fine but
after a few minutes it starts shaking and it looses all
power and it doesn't turn back on..PLEASE ADVISE THANK YOU.
| Posted: May 10 2011 at 8:02pm | IP Logged
I would test the battery and charging system along with the
engine grounds etc. Low voltage and/or high resistance will
do crazy things. Have you had the ECU relay recall
done?????
rwpaint12 Newbie
| Posted: May 13 2011 at 12:51am | IP Logged
Bouhgt a new batery, but i havent done the ECU relay....a
my neighbors mechanic told me to check the GAS
sensor....not really sure if that would be accurate...and
he put the canner and gave two codes...
jgreenjr Senior Member
| Posted: May 13 2011 at 5:28am | IP Logged
he put the canner and gave two codes... |
What are the 2 codes?
__________________ Jackie
A Proud owner of
2003 Nissan Frontier XE
4 cyl.
4x2
auto.
KA24DE
Stereo:Kenwood KDC BT648U
Ham radio since 2001 N4MJG
Tullahoma Tenn
rwpaint12 Newbie
| Posted: May 13 2011 at 11:18am | IP Logged
the codes are P1168 and P1051..
| Posted: May 13 2011 at 7:43pm | IP Logged
P1051 A/F sensor heater B2 (DRIVERS SIDE) this is the front
sensor(used to be called O2 sensor).
P1168 Closed loop B2 (due to the A/F sensor).
Replace the front sensor on the drivers side.
