Subject Topic: AC not working properly Post ReplyPost New Topic
safetyfirst
Posted: May 11 2011 at 7:33am | IP Logged Quote safetyfirst
I brought my 06 frontier to a garage for repair since my AC is not working properly. I said not working properly because if you turn it ON to 1 you can hear the compressor engage and the switch on the dash is lit but if you turn it to 2,3 or 4 the light on the switch doesn't lit. you could feel the air blowing but not cold air. the mechanic thought it was just freon but when he charge it up he said the pressure was too high. I'm reading some of the blogs, is this problem related to thermal control amp too?
Back to Top View safetyfirst's Profile Search for other posts by safetyfirst
Posted: May 11 2011 at 8:03pm | IP Logged Quote frontierguy
Does the blower work on all speeds? Most likely the concern
is with the intake air temp sensor, but it also sounds like
the blower resister is faulty. IS the air cold on #1 speed
setting?
safetyfirst
Posted: May 11 2011 at 8:53pm | IP Logged Quote safetyfirst
On #1 it runs cold but the blower does not blow. On 2,3 and 4 the blower blows but does not blow cold air and it seems like the A/C shuts off and the lights turns off as well. If it's the blower resister, how do I replaced it and where is it located? Thanks for the immediate reply.
06 Frontier SE 4x4 Manual
Posted: May 12 2011 at 8:04pm | IP Logged Quote frontierguy
It is located near the blower motor on the bottom of the
housing.
safetyfirst
Posted: May 26 2011 at 7:47am | IP Logged Quote safetyfirst
Got it. Done.
If I can do it you can do it, it was like connect a dots.
Thanks.
safetyfirst
Posted: May 26 2011 at 8:53am | IP Logged Quote safetyfirst
setting?
I replaced the resistor and speed/switch #1-4 is now working properly except that I'm not having cold air. Is it possible that any valve is clogged? From what I remember, I was told by the mechanic that my pressure on the low side was way low but my highside pressure was above 400, honestly I don't know how to translate that.
bcaughhorn
U.S. - Alabama
Posted: May 31 2011 at 2:08pm | IP Logged Quote bcaughhorn
may be a bad compressor.. if i remember rite mine was the same way and i tried the x-valve first and ended up buying the compressor
Back to Top View bcaughhorn's Profile Search for other posts by bcaughhorn
Posted: May 31 2011 at 8:41pm | IP Logged Quote frontierguy
Has anyone added freon? If so, it needs to be recovered,
evacuated and the proper amount installed. The back to the
intake air temp sensor as mentioned previously.
