| Posted: Jun 20 2011 at 4:08pm | IP Logged
IMHO.. I'd do a simple drain and measure the drainnings then replace that with new fluid of the same amount. Then drive about nine miles and check the fluid level. Add if needed. Have about four quarts on hand. Be sure to use the correct Nissan fluid for your model. The filter is probably just a screen and can be washed.
Try it that way for a couple weeks. If it helps repete the drain process again. A flush might be good or it might bad for it!
Good luck.. Don S..
