Subject Topic: radiator Post ReplyPost New Topic
hoffman5565
Posted: Aug 19 2011 at 4:17pm | IP Logged Quote hoffman5565
ok so i have a 2000 frontier with the 4 cyinder and i have had a problem with it overheating for a lil while now.  last week the top radiator hose split and overheated again so i replaced it and refilled it.  the truck ran great untill today i noticed it leaking from the top of the radiator. it has always leaked somewhere but this is the first time i have ever seen it. my question is why would it leak from between the metal and plastic at the top of the radiator?
Back to Top View hoffman5565's Profile Search for other posts by hoffman5565
Posted: Aug 20 2011 at 7:31pm | IP Logged Quote frontierguy
Poor seal, age, deterioration. That system has a bleed
screw to remove all the air from the system.
hoffman5565
Posted: Aug 21 2011 at 3:17pm | IP Logged Quote hoffman5565
so the radiator would do it without having high pressure becouse something else is wrong?  im wondering if the radiator went bad cause of a bad water pump or something like that.  would air cause it and where is the air bleeder? thank you.
Posted: Aug 21 2011 at 7:57pm | IP Logged Quote frontierguy
Bleed screw is towards the front of the int man. 10mm
socket to loosen.
