| Posted: Nov 07 2011 at 4:41pm | IP Logged
Hello:
I am replacing my drivers side front caliper and caliper bracket. The mounting bolt loosened and came out causing the caliper to lean up against the rotor and damage the caliper and bracket. SOO, I bring in the core return and order a refinished one, and the proplem is that the mounting bolts do not fit to place the unit back on the truck. we ordered another one from another parts place and same thing. In the end I went to several places and all the same result. For some reason the all the remanufactured caliper brackets have a smaller thread than the OEM mounting bolt. SOO whats the deal, how do I fix this? I have found nothing on the web, nor can I even find the smaller size bolt. Ideas?
The truck is a 2001 Frontier SE-V6 crew cab 4x4 non super charged.
