Subject Topic: transmission failure Post ReplyPost New Topic
happydays
Posted: Nov 13 2011 at 6:04pm | IP Logged Quote happydays
hi guys havent being on this site in ages   my 05 NISMO TRANNY   died  at 79500  dealer said it was NOT caused by  COOLANT LEAKING INTO  TRANNY WHICH I THINK IS  BULL  ,ANYONE   KNOW  OF THEM BLOWING NOT RELATED TO THIS REDIATOR   PROBLEM??????  SOLD IT  FOR $3300  JUST GLAD TO SEE THE BACK OF IT   REPLACED  2 FUEL PUMPS    DRIVE SHAFT  PROP , 1 COMPUTER   FUEL SENSOR THE  LIST GOES ON AND ON  REAR  DIFF  ALSO JUNK  WHAT A LEMON  LOVE TO HEAR YOU OPINION   hope to  hear from frontier guy??   thanks  guys   feel better after  venting a little
Back to Top View happydays's Profile Search for other posts by happydays
Posted: Nov 13 2011 at 8:23pm | IP Logged Quote frontierguy
WOW!!!! How was the truck used????? How much of this stuff
failed out of warranty?? The prop shaft(u-joints) are
5yrs/60K- ECU-8yrs/80K - what was the trans doing or not
doing to make it fail? Were you losing any coolant, it only
takes a few tablespoons to destroy the trans- was there any
pink fluid in the coolant over flow tank?
happydays
Posted: Nov 14 2011 at 6:23am | IP Logged Quote happydays
Hi frontier guy thanks for the reply everything was under warranty.
Except computer. $8oo. Did not fix rear diff lights on in dash in. Dec.
Tranny blows in. Jan 2011. Can't member if pink fluid in overflow
tank. Toted. It to dealer service manager was a major a hole when.
Said tranny had blown telling me I did not know what I was talking
about paperworks says transmission fluid is burnt needs
transmission assembly no coolant in automatic transmission
checked for automatic transmission fluid in coolant. None. I just
feel they screwed me. I should have been. A hole back. Do you.
Think. Tranny failed for other reason? We did have really bad
winter in. Northeast?/
Frontier guy I can give you the codes scanned by tech if. That
means anything to you? Thanks for your help
happydays
Posted: Nov 14 2011 at 4:35pm | IP Logged Quote happydays
jus a few more things  i forgot to add this morning  while going to work the truck was never used for  towing etc  most it carried    plywood and studs  tranny  never gave a hint of  trouble  right up to the minute it totally died i mean it went in  1 minute LITILARRY then  it was tow truck time
Posted: Nov 14 2011 at 7:58pm | IP Logged Quote frontierguy
The computer you are referring to, is it the ECU??? If so,
that is covered for 8 yrs/80K miles. If there was no
coolant intrusion, it sounds like the tranny failed for
some other reason.
happydays
Posted: Nov 15 2011 at 5:11am | IP Logged Quote happydays
Hi fortier guy. No it wasn't the ecu think. It was the. Ipbm ? On my
way to work let you know later
happydays
Posted: Jan 03 2012 at 8:32pm | IP Logged Quote happydays
hi frontier guy happy new year  meant to check back before now just a follow up on my frontier   ,got in contact with the guy  i sold my truck to,  he says the coolant did NOT leak into the tranny   ,told me the clutches in tranny were burnt ,does that sound right ?? IS THAT A CHEAP REPAIR??   automatic tranny not  stick by the way
Posted: Jan 04 2012 at 6:57pm | IP Logged Quote frontierguy
It is possible. It is best to replace trans., unless you
can find an independent to rebuild it. Again, any amount of
pink oily crap in the coolant overflow is a definite
indication of rad. failure.
happydays
Posted: Jan 05 2012 at 8:49pm | IP Logged Quote happydays
thanks  for the reply frontier guy  ,is there many transmission failures unrelated to  the  coolant leekage issue??
