mvandine Newbie
Posted: Nov 21 2011 at 7:23pm | IP Logged
I have a 2004 Nissan Frontier XE 3.3l V6 4WD 4-door. I recently replaced the passeger side pre-cat oxygen sensor with a NTK 4 wire universal sensor. The problem is im still in open loop fuel mode. I wired signal (black) to signal on the harness ground (grey) to ground on the harness and both white heater wires to the heater wire on the harness. I know the problem probably lies there but im not sure if i should leave one heater wire un hooked or ground it to the frame somewhere or try to track down a universal 3 wire and replace it all together. Any help would be greatly appreciated.
Posted: Nov 21 2011 at 7:45pm | IP Logged
Why not make it simple, Genuine Nissan???????
mvandine Newbie
Posted: Nov 21 2011 at 7:50pm | IP Logged
Unfortunately there are only two aspects to life, cheap and easy. And easy is directly inproportionate to cheap. In other words, I cant afford it lol.
