| Posted: Dec 02 2011 at 10:14pm | IP Logged
Is it that the key does not rotate the switch or the warnning light won't turn off when the key rotates?
Can you check the wires behind the switch? Something may have pulled it loose.
I believe he means the switch for the child seat turn off will NOT turn the crash bag back on. This is a safety concern for the front seat passeger.
Don S..
