Subject Topic: truck starts ok but has no power Post ReplyPost New Topic
Brad
Posted: Dec 08 2011 at 12:15pm | IP Logged Quote Brad
I have a 1998 nissan Frontier. It starts and idles fine but
when you drive it and try to come up to speed it has no
power, you have to baby it half throttle to get up to
speed. I have changed the NOC sensor, housing , fuel
filters, fuel pump, and have taken it to three different
mechanics who have all failed to find the problem. Anyone
have any ideas?
Brad
Back to Top View Brad's Profile Search for other posts by Brad
Posted: Dec 08 2011 at 5:29pm | IP Logged Quote kcidmil
Does the engine miss or run rough when you try speeding up
normally? Does the engine sound like it's struggling at
all, or just rev and no go?
Also helps to have more info on your truck. Which engine
and transmission
Posted: Dec 08 2011 at 6:51pm | IP Logged Quote frontierguy
MAFS????????????????????   Timing chain may have jumped a
couple of teeth, any more than that and it is not going to
run(bends valves). Also check for any debris down in the
hole for the MAFS. I'm sure you are using a Genuine Nissan
oil impregnated air filter!!!!!????????!!!!!!!!!!
