Subject Topic: 2001 frontier Post ReplyPost New Topic
smathiot
Posted: Dec 09 2011 at 7:34pm | IP Logged Quote smathiot
My 2001 Nissan Frontier remote controls will lock my doors but they will not unlock the doors. I changed the batteries, and still have the same problem. Sometimes after a few minutes it locks it's self. Any ideas?
Back to Top View smathiot's Profile Search for other posts by smathiot
Posted: Dec 10 2011 at 8:03pm | IP Logged Quote frontierguy
Take the remotes to your dealer and have them tested to
verify if they are working or not. Possible actuator,
entrance control module, wiring, connection??????
Posted: Dec 11 2011 at 11:03am | IP Logged Quote kcidmil
If the locks are locking just a few minutes after you hit
the "unlock" button on your remote, then you you've got a
problem with the module, actuator or wiring to it. The
system is programmed to re-lock the doors if you hit the
unlock button on your remote but don't open the doors.
Helps prevent thefts if you accidentally hit the button
while walking away.
If that's your case above, the remote is sending the
signal, and the module is receiving it. Just nothing is
getting to the actuator.
wr426rvdr
U.S. - Arkansas
Posted: Feb 15 2012 at 8:38pm | IP Logged Quote wr426rvdr
I have a 2001 Frontier crew cab.  When it is cold, the door locks will malfunction periodically.  Using the remote, i can hear the lock moving but will not unlock door.  The key will not unlock the door either.  I have had the actuator replaced but problem is still occuring.  Any help.
Back to Top View wr426rvdr's Profile Search for other posts by wr426rvdr
