rsa1 Newbie
| Posted: Mar 16 2012 at 9:13pm | IP Logged
I just got a Frontier XE 06, I want to change ehe oe wheels
and get a KMC's, the only size available in 6 holes is this
6X139 offset -6
Will they fit on the truck?
Front11 Newbie
Online Status: Offline Posts: 22
| Posted: Apr 02 2012 at 11:36am | IP Logged
The wheel pattern is 6 on 4.5 BUT that's not the fit problem. The problem is CALIPER CLEARANCE not lug pattern. Check for caliper clearance.
__________________ 2011 Frontier S
4 cyl. AutoTrans
| Posted: Apr 02 2012 at 12:24pm | IP Logged
Nope, you'll need a 6x114.3 (6x4.5) This is the biggest
problem we've run into with our Xterra. The wife really
likes the Moto Metal skull but they don't make those in our
pattern.
Also Front11 has a point, the calipers are pretty large so
you'll have to check to see if the rims will clear. It's
not so much the diameter, as 16" will clear, but it's the
spokes clearing the sides of it.
A low offset will help in this regard.
