| Posted: Apr 07 2012 at 8:29pm | IP Logged
Good call, I just put a small can of injector fluid in a tank of gas, and Walmart Automotive says the do a good job of flushing out the injectors for $20.00 which I may try next. The truck has 137,000 miles of tender loving care on it, and as I said before, the engine and all parts under the hood are always clean, you could actually eat off the top of the battery with little or no chance of acid contamination. lol. I always use Nissan Parts, they are a bit more expensive but worth the money.
When I have run the engine for a tank or so, I will post again to let you all know if the problem has been solved, I am almost certain it is being cause by a dirty injector.
Mike
