| Posted: Sep 03 2012 at 2:10pm | IP Logged
Hi
Guy's my name is Dickie,
I've owned my 2001 Frontier crew cab SE (auto) since new,
has
70,000 miles on it and has always been reliable,
like
a lot of people here I had my service engine soon light come on,
plus
once transmission is warmed up low rpm gear changes jolt mainly 1st and second,
high rpm changes don't so obviously I floor it
all the time.
but
its inspection time and I have to fix this problem,
so
I changed the oil and filter, transmission fluid and the filter and air filter,
Light
still didn't go out,
I
even treated the old girl to 4 new tires to show i cared but daddy can't get
any love!
so
I went round checked for air leaks and cleaned all the electrical connectors
with QD Cleaner,
still
no joy.
other
issues are blower fan only works in 4th position,
looked
at the wiring diagram and it points to the fan resistor being bad,
so
I came here and started reading the wealth of info and registered.
I took it to the local Auto Zone to get the codes here is what I got,
NISSAN P1705 - Not in P or N During KOEO / KOER.
NISSAN P0733 - 3rd. Gear Malfunction.
NISSAN P0120 - Throttle Position
Sensor Signal Range/Performance.
NISSAN P0731- 1st. Gear Malfunction.
NISSAN P0325 - Knock Sensor Circuit Malfunction.
NISSAN P1441 - Evaporative Emission Control System Very Small Leak.
now I know my wife never
tightens the fuel cap properly but the other codes I need help with please,
so back to Auto Zone and
priced up the following parts,
Knock Sensor,
Throttle Position Sensor,
Transmission Speed Sensor,
O/2 Sensors for Manifolds,
Fan Resistor,
Fuel Filter,
so am I on the right track
with the parts I'm about to replace to get this through the inspection?
am I over doing it replacing
something that doesn't need replacing? also prices between eBay and auto zone are close apart from the Knock Sensor,
they seem to be much cheaper like under $50 on eBay where as auto zone wants $120!
why the big difference am i missing something here?
__________________ 2001 Nissan Frontier Crew Cab 3.3 SE!
1974 Kawasaki F9 350 Big Horn,
1981 Kawasaki KZ1000J1,
1984 Kawasaki KZ700A1,
1997 Honda XR400R,
2001 Honda XR200R,
