Subject Topic: tire noise Post ReplyPost New Topic
trailrunner
U.S. - Colorado
Posted: Jan 16 2013 at 8:09am | IP Logged Quote trailrunner
hi,new here,just bought a 012 crew cab,notice while driving 15-45 mph,have lot of tire noise coming up thru the back of the cab.
any one experince this and is there a remedy for it beside getting rid of the truck?thanks
Back to Top View trailrunner's Profile Search for other posts by trailrunner
Posted: Jan 16 2013 at 9:01am | IP Logged Quote lakota
    Are these the original tires that were on the truck when new? Have you tried rotating the spare into the mix. Spare tires can be deformed in the spare rack. BFG Long Trails run at a fairly low noise level. I moved to BFG AT KO ‘Tri Guard’ one size larger. The over all noise increased a little but worth it for running on sharp rocks in the Colorado Mountains.
    There is a rare condition were a tire can be slightly out of round yet balance good. BUT it will become noisy and a little unbalanced at speeds below 40mph. Also hidden tread separation is a possible cause.
Good Luck.. Don S..
Boomer
Posted: Jan 16 2013 at 5:53pm | IP Logged Quote Boomer
There is, if I remeber, an air vent behind the back seat.  It does allow for ventilation but does admit some noise.  Lower the seat backs and look for it.  You could put a towel or something infront of it if that is the cause.
2007 Nissan Frontier SE 4X4
trailrunner
U.S. - Colorado
Posted: Jan 16 2013 at 7:53pm | IP Logged Quote trailrunner
truck has 14000 miles on it when l bought it,l thought of the vent behind the rear seat
l put some tape on it ,no dif,planning on rotating the tires tomorrow and see what happens,its more irratating than anything.thank for any info.
