Posted: Mar 12 2013 at 6:41pm | IP Logged
For you guys w/ rough, erratic idle with A/C on, there is
an ECU
reprogram available now to address this concern on '10-'12
Frontier w/ auto trans. NTB13-021
FrontierME Newbie
Posted: Jun 03 2013 at 9:18pm | IP Logged
I've just noticed that my 03 is beginning to run rough with
the AC on. Whats' the fix?
Thanks
MP
__________________ Thanks
FrontierME
03 Frontier CC SE
95 Hardbody
07 Jeep Commander
70 Datsun 240Z
davidjbrady Senior Member
Online Status: Offline Posts: 358
Posted: Jun 04 2013 at 9:18pm | IP Logged
Hello, I see that this TSB applies to 10-12 and not an 08 like mine. The issue I am having is that after truck is warmed up, say I drive 10 minutes to store. I turn it off, and then come back 30 minutes later to go home.
With the AC on and leaving the parking lot, If I am waiting to leave the exit/entrance, once I turn the steering wheel, I can feel the idle getting rough. It is like back in the old days where a carburetor needs to be "cleared out" by revving it a bit. Will the idle learn fix this? It is idling around 550 RPM at this point when its rough. It dissipates for the most part once I get moving, afterwards.
Thanks,
David
motoxracer725 Newbie
Posted: Jun 05 2015 at 3:02pm | IP Logged
i also too have a 2008 frontier and mine does the same
thing. i just got mine last week so im new to the
problem. from factory once warmed idle should be at
650rmps. or give or take 50. so if its around that
range then thats where it should be. but due to being
that low the engine has a hard time keeping it self
running smooth at idle. if you are at a stop light and
put your foot on the brake and bring the idle up to
around 750 or so it is alot less worse. so the answer
is turning your idle up. nissan knows about the issue
and will turn it up for you but at the cost of there
hourly rate. or what im still looking into is i heard
people using the bullydog tuner or the superchip
cortex to turn the idle up. i have called both
companies and they have said that they can not. so if
anyone has done it that way i would like to know how.
caddss Newbie
Posted: May 25 2016 at 6:38pm | IP Logged
Anyone have an idea of what Nissan should charge to
reprogram the ECU.a
jgoedhard Newbie
Posted: Sep 15 2020 at 7:13am | IP Logged
Could try to clean your throttle body, and IAC if
you have one.
Ray's Frontier Newbie
Posted: Mar 17 2023 at 11:43am | IP Logged
To increase the idle speed watch this youtube video.
https://youtu.be/RWWWip62XNQ
Posted: Apr 21 2023 at 11:02am | IP Logged
How to adjust your idle.
https://youtu.be/0nl3ZKyI3ac
