Subject Topic: pulling engine :o/ Post ReplyPost New Topic
millarg
U.S. - U.S. Virgin Islands
Posted: Jun 13 2013 at 5:51pm | IP Logged Quote millarg
2000 4x4 manual Frontier V6 3.3L Crew Cab
Trying to pull engine, all disconnected , is there a trick to getting
engine out without dropping transmission?
I've run out of room, deepest pan of oil pan is touching cross member
and output shaft is not clear of manual transmission!
TIA
2000 V6 CrewCab Manual
Back to Top View millarg's Profile Search for other posts by millarg
Posted: Jun 13 2013 at 8:08pm | IP Logged Quote frontierguy
Have you removed the front diff. assy.?
millarg
Posted: Jun 14 2013 at 9:26am | IP Logged Quote millarg
No, it is actually the front diff that is holding the engine back.
So by removing the diff I should have enough room to pull engine forward and lift out?
Sorry if this sounds stupid, I'm having the work done and getting the story by phone, I check the Haynes book, but it is clearly written for 2wd.
TIA
Posted: Jun 14 2013 at 8:20pm | IP Logged Quote frontierguy
Yes, front diff needs to come out.
millarg
Posted: Jun 15 2013 at 10:19am | IP Logged Quote millarg
Thanks guys
