csagenlee Newbie
| Posted: Jul 16 2013 at 1:44am | IP Logged
I have a 1998 2.4L 5 speed and I think maybe the clutch is out but I am not 100% sure that is the problem. I have no forward or reverse and when it is in gear it still rolls as long as it is on a hill or I push it. Not sure what is going on with it.
__________________ 1998 Nissan Frontier King Cab 4x4 2.4
The Dark Knight Newbie
A White Knight it the Dark
| Posted: Jul 16 2013 at 9:10am | IP Logged
Make sure the transfer case is is not in Neutral.
What happened when this problem started. Was someone else
in the truck?
csagenlee Newbie
| Posted: Jul 17 2013 at 11:20am | IP Logged
T-case is not in neutral and I was in the truck when it happened. It
wasn't all at once it happened slowly over the course of about three
days
| Posted: Jul 17 2013 at 3:49pm | IP Logged
sounds like the clutch is toast or the counter shaft in the
trans has failed bearings which alows the shaft to drop
down not allowing gear engagement.
