Subject Topic: 2000 Frontier A/C Electric Fan Post ReplyPost New Topic
windyharbor
U.S. - Illinois
Posted: Jul 17 2013 at 10:10am | IP Logged Quote windyharbor
Hi,
Have a 2000 Frontier V6 4x4. The electric fan for the a/c comes on after driving for about 5 miles. A/C isn't on. Engine isn't overheating, temp gauge working fine.
Any ideas as to why the fan is always on after short drive ? A/c is cooling fine also, but as I said it isn't even on and the fan comes on. Clutch, belt driven fan seems to be working fine. I thought electric fan was just for a/c use.
Back to Top View windyharbor's Profile Search for other posts by windyharbor
Posted: Jul 17 2013 at 4:02pm | IP Logged Quote frontierguy
it is controlled by the ecu and the triple pressure switch.
i don't have info at home on the parameters for operation.
if the ambient temp is high and a/c is not on, i believe it
should operate.
windyharbor
U.S. - Illinois
Posted: Jul 18 2013 at 4:51am | IP Logged Quote windyharbor
Ok, Thank you for your reply. After checking things out more, I think I am going to have to replace the fan clutch. Not much resistance when turning it by hand and some play in it. Seems to be the reason electric fan is coming on.
