NIssanJess Newbie
| Posted: Jul 23 2013 at 2:52pm | IP Logged
I have a 2006 Nissan Frontier Crew Cab. About a month ago, I started hearing this whining noise when starting it then it would go away. Within about a week, it was consistent. I had a non-professional friend tell me he thought it might be the power steering pump. The more I read on it, it seems it may be the timing chain tensioners. The problem with that is when I listened to videos people posted online about that issue, it didn't quite sound the same and it doesn't change with acceleration like it did in the videos. I don't know that I want to trust someone that's not a licensed mechanic but I really don't have the funds to get it looked at right now since I got laid off 5 months ago and just returned to working. I am supposed to be taking a 3 hour trip next week and I'm terrified that something might happen. I haven't had any problems with it other than the noise but I know long distance driving can put stress on anything that may already be wrong. I would love to upload a video of the noise but I'm not sure if there's a choice for that on this website. If anyone has had this problem and knows if it can get worse, please let me know. I need to do something about it soon but until I have the funds, I'm just praying it isn't anything serious.
Boomer Senior Member
| Posted: Jul 24 2013 at 6:21am | IP Logged
The tensioners can fail easily. Mine were replaced under warranty at about 34,000 miles. The whine was noticeable and while there was some correlation to RPM, it was like a steady whine. If you drive on them when they are worn, your timing chain is eating into the metal supports and you will have more damage as well as metal particles in the engine.
Without hearing it, it is hard to diagnose.
Peninsula2010 Groupie
| Posted: Jul 24 2013 at 6:32pm | IP Logged
Why are tensioners going bad so soon? Something leads me to
believe it's a lubrication issue in other words the oil is
shearing and not able to lube the VQ40 engine properly.
I started using Mobil 1 fully synthetic oil and OEM filters
on my 08 Frontier and you would not believe how quiet the
engine is for a V6 since using this oil
| Posted: Jul 24 2013 at 7:17pm | IP Logged
Another source of whine noise will come from the PCV system
on this engine. Sometimes changing the PCV valve(with
Genuine Nissan) or changing both valve covers is required
to correct the concern(it is more annoying than hamfull).
It is not the tensioners that fail, it is the plastic shoe
at the end of the tensioner that contacts the chain that
fails, and again, if this is the source of the noise, it
will increase w/ RPM.
| Posted: Jul 24 2013 at 7:59pm | IP Logged
I have used Mobil 1 from the first oil change in my Fronty and changed it every 3500 miles with a new filter each time. Tensioner plastic shoes still wore through in less than three years.
| Posted: Jul 24 2013 at 8:17pm | IP Logged
through in less than three years. |
That's insane ,looks like it is a bad design from Nissan
then? Are they warrantying it or what?
| Posted: Jul 25 2013 at 12:30pm | IP Logged
Warranty is only for the 3 year, 36,000 miles. It is a bad design made with bad plastic, IMHO.
