Subject Topic: metal in oil Post ReplyPost New Topic
ngrego2
U.S. - Maryland
Posted: Oct 25 2015 at 8:00am | IP Logged Quote ngrego2
I have a 2003 nissan frontier xe with the 3.3 liter engine
with 146000 miles. the past two oil changes i have found a
silver colored metal in the oil pan. the pieces are small
but big enough to feel like sand between my fingers. I am
not very automotively inclined and other than routine
maintenance i have done nothing to this trucks engine. any
ideas for what this could be or how i should proceed would
be very helpful. thank you in advance.
Back to Top View ngrego2's Profile Search for other posts by ngrego2
Posted: Oct 25 2015 at 12:57pm | IP Logged Quote lakota
Have you split open an oil filter to see what it might be catching?
There are companies that can tell you what the metal is coming from... if you send an oil sample.
Good luck with it .. Don S..
Rubble
Posted: Oct 25 2015 at 3:43pm | IP Logged Quote Rubble
More info would be helpful;  Are you the original owner,  what region of country, oil viscosity being used, brand of oil filter used, mileage between oil change's, oil consumed between oil change's,  any trouble with the timeing belt, timeing belt changed on time?
How's the Engine Running, Any Engine Noise such as Ticking, Knocking, Rattleing?
Do what Lacota advised.
Ask the Nissan Master Tech if normal or not.
Let us know.
ngrego2
U.S. - Maryland
Posted: Oct 27 2015 at 11:18am | IP Logged Quote ngrego2
I am not the original owner but bought the truck at
130000 miles. at the time i bought it and the couple oil
changes before the last two i did not notice any metal
bits in the oil. I live in Maryland so it is not very
extreme climate wise. the oil i have been using is
penzoil high mileage and the viscosity is 10W-30 as the
owners manual suggests. I also change the oil every 3000
miles and have not noticed a large amount of oil
consumption maybe a quarter of a quart from the amount
put in to the amount out for the next oil change. As i am
not the previous owner i do not know f the timing belt
has been changed but as of now i have also not heard any
unusually noise or felt any changes in the way the truck
has run.
Rubble
Posted: Oct 27 2015 at 1:10pm | IP Logged Quote Rubble
has run.
Knowing what I've learned about Nissan since 1993, this is what I would do.
What Lacota Said +  Talk with the Nissan Master Tech and the Service Manager, to see what they say is Normal for metal particle's in the Oil.  Your engine is starting to use a little bit of oil, some may be from leakage, but if no leak's then I would suspect maybe ring  particle's, but that's just a wild guess.
Use a Nissan Oil Filter, they cost a little more,, but on Ebay and Amazon,, they cost less than at the Dealer.  Don't take chance's with an after market Oil Filter trying to save a little bit of money.  Nissan oil filter's are not the Very Best,, but they are way above the Worst,, and are engineered for the Nissan Engine.  Correct Oil Lubrication is about the same as the Correct Blood Circulation for us.  If you've got a low end oil filter like a Fram, get that thing off ASAP, and put a Nissan Oil Filter on.
Ask the previous owner if the Timeing Belt has been changed and where at to verify.  Some engine's if the Timeing Belt Break's there is a Valve and Piston overlap, if your engine is that way serious Engine damage will likely result; ask the Master Tech if your engine is that way.  Some Engine's the Valve's and Piston's don't over lap and won't do as much damage, if the Belt Break's while running.
Double check the Viscosity, I think that you'll see under the hood that it recommend's 5w30, but I don't know that 10w30 would be too thick, as long as the outside temperature doesn't go lower than 0 F degrees.
You might be able to find out from Nissan by the Vin #, what Service your Engine has had.
HTH, & Good Luck
ngrego2
U.S. - Maryland
Posted: Oct 28 2015 at 4:28pm | IP Logged Quote ngrego2
If i send the oil to a company to test it, what will i get
back from them? Will they be able to tell me what kind of
metal it is and what part of the truck it came from or will
it just be what type of metal it is. And if you guys know
any good companies for this type of thing and are willing to
chare i would appreciate it.
Thanks to everyone so far!
Posted: Oct 28 2015 at 7:25pm | IP Logged Quote lakota
Most I have seen you order a kit with a mailer in it. It has a tube for the oil sample. They have to know what engine you have and they tell what the contaminates are and where or what part they came from.
You might try a search for "Automotive oil test kits".
Good luck with it.. Don S..
