Subject Topic: fuel efficiency Post ReplyPost New Topic
mick-f
Posted: Nov 22 2015 at 1:06pm | IP Logged Quote mick-f
Just wondering, are there any tires that give better fuel mileage, and also, does synthetic oil make a difference in fuel mileage?
2012 Pro 4X off road, crew cab.
I don't plan on going off road, but if the ZOMBIE APOCALYPSE happens that may change.
Back to Top View mick-f's Profile Search for other posts by mick-f
Posted: Nov 22 2015 at 2:15pm | IP Logged Quote lakota
Welcome to the group!
   I stated playing with fuel mileage in 1950 in my 1940 Plymouth. My next car was a new 1951 Studebaker Champion. The absolute best way to gain fuel mileage is... Get ready for it...
Losing weight in your right foot.! Or tape a raw egg the pedal.
    Next, use the brakes VERY lightly. When you use the brakes it means you're burning off speed that you used gasoline to get. Get off the gas and coast a bit then use the brakes. Most people are in a hurry and try to get all the speed they can then smack on the brakes for the stop sign they knew was there.
    Synthetic light weight oil and more pressure in the tires will help a little as will a clean new Nissan air filter.
I like putting 4 oz of Pennzoil Synthetic outboard oil in twenty gallons of name brand regular gasoline. It will retard the build-up of carbon and add upper lubrication... like the valve stems.
Have a good one.. Don S..
Edit;
Large off-road tires are bad for fuel mileage.
Rubble
Posted: Nov 22 2015 at 10:28pm | IP Logged Quote Rubble
Mick,
Lacota covered it pretty good.
Tire's do have a Rolling resistance that does make some difference:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=1 75
I'm averageing 20.6 mpg with my '13 AT 2wd svv6 Frontier, and that's mostly in mixed driveing.
Like Lakota said, the Brake's eat up the Fuel Mileage, so the less that they are used the better for Fuel Mileage.   Learning to judge the red light's and reduceing the speed, ahead of time, and avoiding a full stop help's mpg, cause it take's more fuel to get going again from a full stop.  That also help's to prolong the Brake pad's, which is a Win Win.
Takeing off slowly, rather than giveing the engine a lot of gas, also help's a lot in MpG.
One other thing that really help's me, is that I make a list of what I need, and try to get everything that I need when I make a trip into Town.  I'm retired, so that help's me a lot, but I started doing that when I was employed as well.
I think Lakota covered everything else, and like he said, monitor the Tire pressure and keep the pressure at least what's recommended by the Owner's Manual.
I've alway's kept a little pocket notebook in my Truck's and check the Fuel Mileage @ every Fill up.   That let's me know, what the mpg's are,, but also if the mpg's start falling off, to alert me to double check thing's to make sure that the Engine or something else in the DriveLine might need some attention.
Hope I didn't ramble on too much, but I get a kick out of trying to get the best MPG's that I can out of my Current and Past Vehicle's.
HTH & Good Luck
